How difficult is a leveling kit install?
Old May 24, 2011 | 07:35 PM
team_realtree's Avatar
team_realtree
Originally Posted by Matt99
yea well lifting an 06-08 2wd is a ton different than the previous years. If you do a little searching, you will see the problems that are attributed to the UCA mainly. It comes in contact with the spring bucket because it is so thick
Someone put on a readylift the other day and says it rides like stock. Its over $300 I think. Its a driveway install. The other option is the spindles like weed mentioned. I just installed them. Overall I think they are quite a bit easier than the spacer install and they are only $270 including shipping.
Heres my 07 2wd with a 2.5in level, 3in spindle, and 3in body.
Where did you get the spindles at? Did you need any specialty tools or was it pretty easy? Also does it do anything to the rear or just bring the front up?
Old May 24, 2011 | 08:55 PM
LazyLightning's Avatar
LazyLightning
Matt,that is just, biiiiiitchen!
Old May 24, 2011 | 09:31 PM
Matt99's Avatar
Matt99
off ebay from pricebusterchris but they are just airbagit.com spindles. It was easier than installing coil spring spacers and I made a DIY on it. It just brings the front up
thanks man.
Old May 24, 2011 | 11:56 PM
Razorhawg's Avatar
Razorhawg
i totally recommend the readylift i put one on about a month ago and love it rides great and still havent really heard the uca spring bucket contact but i dont do any off roading at all just a pavement pounder and a dirt road goer
