leaking front diff oil got some ?s
just wondering if any of you have taken off your front diff cover to change the oil haven't really looked at how hard it is to get at. and im also wondering if there is a certain kind of oil i should use to fill it back up.
front diff should be 80 90 gear lube
rear diff 90 145.. gear lube ,if you have posi rear u need additive..
use gray silicone to put the cover back on.also DONT crank the bolts to tight..I dont know the torque spec but I see these new front ends are aluminum on 1500.
simple job.
simple job.
thanks for the reply is there any brand of oil preferd i shouldn't need to use full syn on the front diff should i. i had 1L of castrol 80 90 that i used to top it up till i get the chance to do it.
