2003 Ram 1500 Transmission slips
Old May 26, 2011 | 02:47 PM
jagjeffers's Avatar
jagjeffers
Default 2003 Ram 1500 Transmission slips
When tranny goes to 3rd gear the RPM's rev up and truck lacks power. If I put selector in 2 or 1 to prevent shift all is ok. Saw some info about Transmission output speed sensor, could this be the problem? 91,000 miles and never a problem.
Old May 26, 2011 | 07:59 PM
lxman1's Avatar
lxman1
Site Moderator
Nope, when ya get that code, it means there is too much of a difference between the input shaft and output shafts. AKA slipping. The computer has a predetermined range of speed difference for each gear. If it goes too high, it is detecting slipping. It could be a bad 2-3 shift solenoid causing it not to go into 3rd gear properly.
Old May 26, 2011 | 11:18 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Welcome to the site. With 91k on it, when was the last time you changed all the fluid and filters.
Old May 27, 2011 | 07:10 AM
jagjeffers's Avatar
jagjeffers
last tranny service was around 50k.
Old May 27, 2011 | 07:51 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Not too bad. Are you getting any specific codes that help dictate the issue
Old May 27, 2011 | 10:35 AM
Rich 2500's Avatar
Rich 2500
Sounds like a problem with the OD clutch, I'd drop the pan to look for flakes or pieces.
