transfercase linkage?
Old 05-28-2011, 10:30 AM
draco8494's Avatar
draco8494
draco8494 is offline
Default transfercase linkage?
allright so the other day i was cleaning the iside of my truck and i bumped my 4wd stick and it just moved back and forth...look under the truck and the linkage fell off right where it connects to the stick...anybody know what kind of pin and or clip goes there to hold it on? i was just going to buy an assortment of pins and try until one fit, but its looking more like it was a C clip...just not sure. thanks
Old 05-28-2011, 04:48 PM
draco8494's Avatar
draco8494
if sombody could look at theirs maybe? lemme know whats holding it on??
Old 05-29-2011, 12:18 PM
mike_r's Avatar
mike_r
mike_r is offline
I'll take a look for you later today.
Old 05-29-2011, 12:53 PM
draco8494's Avatar
draco8494
cool appreciate it
Old 05-29-2011, 01:11 PM
outcast's Avatar
outcast
outcast is offline
mine did that and its just a rubber bushing that holds the conacting rod in and thats it and u cant just buy one peice u have to buy the whole as. or find a wrecked truck and atleast u was cleaning ur truck when u found out i was burried and had to dig a hole under my truck to put it in 4x4
Old 05-29-2011, 01:22 PM
draco8494's Avatar
draco8494
haha yeah i had to do that the other day..so uhh...that kinda sucks, the rubber just holds the rod inplace....no bueno
Old 05-29-2011, 04:43 PM
mike_r's Avatar
mike_r
mike_r is offline
On my 04, 1500, it's just the same hardware that you would find under a bathroom sink for the drain. Just a bolt that holds the rod by friction.
Here is a picture.
Old 05-29-2011, 06:41 PM
draco8494's Avatar
draco8494
that parts still on, the peice that goes through the shifters rubber gromet is what fell out...
Old 06-01-2011, 04:14 PM
weedahoe's Avatar
weedahoe
weedahoe is offline
Hall of Fame Member
Can you take a picture for us?
Old 06-05-2011, 12:08 AM
bigjims's Avatar
bigjims
bigjims is offline
mine did the same thing had to go to the dealer for 2 rubber grommets no bigger then a dime 30 bucks they said its common thing if you loose the shifter rod it will cost over 100 frog skins just for the rod its self
Quick Reply: transfercase linkage?
