I need Help
Old May 28, 2011 | 07:56 PM
6tts66's Avatar
6tts66
Default I need Help
I have a 2002 Dodge Ram 1500 4x4 with a 5.9L engine auto w/ overdrive and my transmission is giving me problems. I have enough fluied in it but it jerks with it shifts into second and it shifts fine 3rd and 4th. At first I thought it could be a shift solenoid so I changed that plus I've changed the fluid. I've had a transmission tech look at it and they couldn't pen point the problem. The truck does have high miles on it, 127,000.
Does anyone know if I could put in a heavy duty transmission in it? Does anyone know other Transmission sites I could look at?
Old Jun 1, 2011 | 04:22 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Welcome to the site
You can certainly put a better built trans in it. Try seeing is Sharadon has any
Old Jun 1, 2011 | 04:45 PM
Matt99's Avatar
Matt99
auto trannys are just not holding up much over 100k. I have a friend with a ford and a friend with a chevy that just got their trannys replaced, both between 110k and 120k. I think they both were around 1100. This comes close to matching the symptoms the Chevy guy had and then it just went into limp mode one day
