Transmission pan/fan
Old May 30, 2011 | 04:43 PM
jones.aaron88's Avatar
jones.aaron88
Smile Transmission pan/fan
I know I'm asking a lot of questions. But I would like to put a better fan on the radiator thing for my transmission, and also a bigger transmission pan. Where can I find these parts at?
Old May 30, 2011 | 04:49 PM
Blacksport's Avatar
Blacksport
Do you mean an oil cooler? You can pretty much get an add on oil cooler from any parts store in your area. Same with the Pan. Or you can try: www.google.com
Old May 30, 2011 | 05:21 PM
HammerZ71's Avatar
HammerZ71
The electric fan on the tranny cooler is actually pretty efficient. For a larger pan, you'd want a PML or MagHytec, can be found all over the 'net. Moe's Performance has or at least one time had both of them...
Old May 30, 2011 | 08:07 PM
jones.aaron88
Ok thanks guys. I wanted to say it was oil cooler, but I wasn't sure. I will go look at those parts asap.
Old Jun 1, 2011 | 04:06 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
You can get a bigger trans cooler though from a 1 ton truck and use it. it is a direct swap.
