gauge cluster dies and sometimes wont start
Old May 25, 2011 | 07:18 PM
eelding's Avatar
eelding
Default gauge cluster dies and sometimes wont start
hi,
i have a 2005 ram 4x4 5.7 power everything. the problem i am having is my gauge cluster randomly dies and all of my warning light come they will eventually come back, also when my gauges gone looses power or whatever happens if i shut the truck off some times it wont start turn the key and nothing< i have already tested the gauge cluster by turning the key ahead and holding the trip button it runs through all functions checked for codes and got a bad o2 sens and a gauge cluster has lost communication code will post the codes later any help would be appreciated this is driving me crazy
Old May 25, 2011 | 08:03 PM
Gone Fishin's Avatar
Gone Fishin
Its sounds like you may be loosing bus communications from the fcm or pcm. Might be a good idea to pull bat power and check all the computer connections, look for corrosion, especially the fcm under the fuse block
Old May 25, 2011 | 09:42 PM
eelding's Avatar
eelding
will check tomorrow,,, is this a common problem wit these trucks
Old May 26, 2011 | 09:20 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Also might try checking the connections at the back of the IC also
Old May 26, 2011 | 04:54 PM
eelding's Avatar
eelding
Checked the FCM and all other conections no visible corrosion I will check the conections on the back of the gauge cluster, so a bad cluster would disable the vehicle
Old May 26, 2011 | 08:16 PM
Gone Fishin
No,
I have a 2005 2500 with no problems of that sort yet.
Sometimes yes, sometimes no--I've heard guys here having problems with the earlier pre-canbus system, where they'll run without the cluster and sometimes not
Old May 26, 2011 | 11:32 PM
Owensue's Avatar
Owensue
Do you have a heavy keychain?
Mine caused my cluster to go out once or twice while driving, a wiggle of the keys and it all lit back up. I've since limited my key weight.
Old May 27, 2011 | 11:33 AM
eelding's Avatar
eelding
I have been doing some surching and I think it may be my fuse box, I have no reverse lights, ic dies , intermittent wippers not so intermittent, won't start some times. It seams like a lot of people have had issues with these fuse box and I think dodge should take responsibility, it is clearly a design flaw or at least a discount on the part . My dealer is telling me the can tell me what is wrong by doing a scan it cost 89 but what's the chances of them finding it and what's the chances of getting out of there for. Just 89 . Do anybody else sell the fuse box besides the dealer? I have owned a lot of cars and never did a fuse box go this is a saftey issue and dodge should be accountable
Old May 29, 2011 | 02:16 AM
Owensue's Avatar
Owensue
search in scrapyards or even on craigslist
I found one recently for cheap.
Have you checked for oxidized connectors etc?
Disconnect your battery negative, then pull the fuse box, there's a bolt on the fender and a plastic screw in the front. All the connectors have locks on them, undo the lock (slide red tab down) then spread open with the white cover and work off. They are color coded.
There can be oxidization on the connectors, but the real issue is the circuit board inside. You can take apart the fuse block to further inspect it.
Old May 30, 2011 | 12:29 AM
oneHEMI57's Avatar
oneHEMI57
This is symptoms of weaking ground point(s). If the gages continue reading correct
when they do come back on.
I had this similar ordeal with a '95, pealed the boot back and the lower contacts
were cover with corrosion.
Do get back and let us know of your solution/resolve.
