Odd smell coming from ac vents
Old Jun 5, 2011 | 09:37 PM
kust3mz's Avatar
kust3mz
Originally Posted by RAM_IT_07
If the ac is blowing hard , cool, and draining then your ok . Im not a 100% sure id you have a in cab filter but if you do change it out and clean your coils and you should be good to go
Blows hard and kinda cold not as cold as it once was and its draining perfect and it does not have a cab filter
Old Jun 5, 2011 | 09:54 PM
bwheelersc's Avatar
bwheelersc
Outside inlet is in the black plastic vents around the windshield wipers.
Old Jun 5, 2011 | 10:05 PM
RAM_IT_07's Avatar
RAM_IT_07
Put a set of gauges on it and check the freon, or put sum dye into it and get a pair of uv glasses and light and check for leaks ..... I had the same prob on my silverado turned out i had a small leak inside the cab
Old Jun 6, 2011 | 01:16 AM
Owensue's Avatar
Owensue
BP makes a product called frigi clean which is a foam spray to clean your evaporator coil, and another called frigi fresh to help eliminate the odor afterwards ( or used on it's own for a wee bit of help).
From what I found searching you can buy it online or at some dealers.
I'm trying to find some here in Ontario.
Old Jun 7, 2011 | 08:37 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Originally Posted by bwheelersc
I just spray Lysol in the outside inlet to the air system with the ac on and blowing on high, then i do the same with the recirculation on, and spray it in the inlet, mine is behind the dash glove box. It gets ride of the smell and will kill the mold if there is any.
Thats what we did in my wifes Mini Cooper also. Worked great. Used the whole can almost though....LOL
Old Jun 7, 2011 | 01:30 PM
lungman's Avatar
lungman
I don't know if this will help but my buddy recently had a mouse family nesting in his fan box. When he cut it on he chopped everybody pretty good and with the heat they stunk the thing up pretty good when he turned the fan on any setting not just AC. Ford stealer got him for 400 to take it apart and clen it out.
