Has Anyone Debadged?
Old Jul 10, 2005 | 03:40 AM
Big_K9's Avatar
Big_K9
Default Has Anyone Debadged?
I want to debadge my truck but was wondering how difficult it was. Is it 3M tape or some different adhesive. Thanks
Old Jul 10, 2005 | 03:46 AM
vipersforsale's Avatar
vipersforsale
Default RE: Has Anyone Debadged?
most of the badges are simply "stuck" on with the 3m style double sided tape... best to use a heat gun or really high wattage hair dryer to heat up the emblem a bit, makes the adhesive a bit more plyable. If you live here in Texas you dont need to preheat it, the 100 degree sun will due just fine. Just take a really good hold on that baby and pull. And contrary to some peoples ideas, dont use anything like a screwdriver to pry it off. Your likely to either dent the metal or scratch it. Home Depot and Lowe's both carry plastic paint scrapers that are much cheaper than having a dent pulled or paint repaired.
Old Jul 10, 2005 | 12:17 PM
Scratch's Avatar
Scratch
Yes, I am working on it. A little word to the wise. I haven't pulled a badge yet where the tape didn't slplit and leave most of the foam on the truck. I tried using the Goo Gone and found it still difficult to get the rest of the glue off the truck. Then I tried using charcoal lighter fluid and it peeled right off. Let the lighter fluid soak for about 20 seconds before you pull it off and make sure the remaining material is saturated.
Old Jul 10, 2005 | 12:52 PM
Hallman's Avatar
Hallman
Scratch, thanks for the lighter fluid tip. I just finished the tailgate and I knew there had to be an easier way. I will try the lighter fluid on the door emblems.
Old Jul 10, 2005 | 04:21 PM
|3|ackAc|D's Avatar
|3|ackAc|D
accualy, the way i debaged my truck was, tooth floss and goo gone and some elbo grease, patience is key..
Old Jul 10, 2005 | 07:56 PM
Big_K9's Avatar
Big_K9
Did anybody run into any probs with the paint being diff. color or anything like that. Thanks
Old Jul 10, 2005 | 08:57 PM
Scratch's Avatar
Scratch
You would probably only have to worry about that on older trucks if the paint has faded. Mine was the same color.
Old Jul 10, 2005 | 11:04 PM
|3|ackAc|D's Avatar
|3|ackAc|D
nope, no paint peeling
Old Jul 11, 2005 | 01:29 AM
Big_K9's Avatar
Big_K9
Any estimates on how long the process took?
Old Jul 11, 2005 | 02:46 AM
vipersforsale
instead of using lighter fluid, try using 3M adhesive remover, you can purchase small cans of it at Pep Boys or go to your local auto paint supplier and get a large can of it. Its great for getting grease out carpet too... and it wont eat your paint off, only wax. If you heat up the left over adhesive with a heat gun then you can rub it off with your thumb and fingers, sure it still takes time.. just less of it.
