Need your Help
Old Jun 13, 2011 | 04:31 PM
96cobravert's Avatar
96cobravert
Default Need your Help
Im sure this is a common problem, however I have searched thru 30 pages or so and have found some things that were similar but not really. So dont beat me up to bad for asking this. When I start from a dead stop, I hear like a faint moan from my driver side wheel area but quickly goes away. It doesnt do it when I turn from a dead stop tho. And to top it off, it only does it like 80% of the time, not always. Do you think it is the hub, bearings or something else, and should I be worried
Old Jun 13, 2011 | 08:59 PM
Owensue's Avatar
Owensue
If it only does it after stopping, it could possibly be a sticking caliper even.
Old Jun 13, 2011 | 09:08 PM
lxman1's Avatar
lxman1
Site Moderator
Jack up the front. You should be able to feel it when spinning the wheel.
Old Jun 14, 2011 | 11:41 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Could also just be suspension related that when you are at a dead stop and moving forward the weight of the truck is shifting
Old Jun 14, 2011 | 01:17 PM
96cobravert
thank guys, ill try that and go from there. come to think about it, it would make sense that its sticking, easy fix? or should I take it to a shop?
Old Jun 14, 2011 | 02:16 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Im sure it is an easy fix as long as you can locate and identify the noise
