07 leveling kit questions
Old Jun 14, 2011 | 08:17 PM
ramin44s's Avatar
ramin44s
Default 07 leveling kit questions
I have a 07 ram 2wd i really want to level and put 33s or 35s if I could get a kit that would fit them without being to stuffed, but anyways all I can find is a readylift and the daystar 1.5 does anyone have any suggestions or opinions on what i should run? here is my truck thanks
Old Jun 14, 2011 | 09:23 PM
Matt99's Avatar
Matt99
One of the most frequently asked questions. Do a search on here nd you will see.
IMO spindles are the best bet. You will need more than a level to fit 35s and you have 33s now. Look up Pricebusterchris on EBay for the spindles, $270 and easy install
Old Jun 15, 2011 | 01:34 AM
Razorhawg's Avatar
Razorhawg
ive got the readylift and im super happy with it but if youre wanting the most height possible go with the spindle i think youll gain 1/4 to 1/2 an inch more with them but you could always put both the spindle and the spacer together and then add a block in the rear and have almost a 6" lift
Old Jun 15, 2011 | 04:51 AM
Brandon Anderson's Avatar
Brandon Anderson
+1 on the spindles, but unless the early 3rd gen spindles fit on the '06+, I don't see any from Pricebusterchris currently.
Old Jun 15, 2011 | 09:11 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Welcome to the site.
Old Jun 15, 2011 | 11:42 AM
Matt99's Avatar
Matt99
The early ones fit ours open it up and read
Old Jun 15, 2011 | 01:20 PM
ramin44s's Avatar
ramin44s
Originally Posted by Razorhawg
ive got the readylift and im super happy with it but if youre wanting the most height possible go with the spindle i think youll gain 1/4 to 1/2 an inch more with them but you could always put both the spindle and the spacer together and then add a block in the rear and have almost a 6lift
Do you have any pictures of ur Truck with the ready lift? I've been thinking about just getting that
Old Jun 15, 2011 | 02:53 PM
Razorhawg's Avatar
Razorhawg
Before:
After:
Before:
After:
im gonna take some more pictures one of these days
as you can see im need of some new wheels and tires also
Old Jun 15, 2011 | 03:37 PM
ramin44s's Avatar
ramin44s
That looks good man thanks for posting those pics
