lamp out warning light??????
Old Jun 16, 2011 | 12:33 PM
silversioux's Avatar
silversioux
Default lamp out warning light??????
I keep getting my lamp out warning beeping at me yet I don't have any bulbs out! Now I get my left turn signal to click fast which tells you there is an issue there then it goes away the next time I do it! All lights work when I put the brakes on, headlights, turnsignals, interior lights??? What gives?
Old Jun 16, 2011 | 12:45 PM
rbrumm's Avatar
rbrumm
It is the left tailight assembly. I have the same problem when it gets cold, the connections don't make good contact. From what I read on here it is a cheap and easy fix. I have just put up with it until it becomes constant.
Old Jun 16, 2011 | 04:17 PM
silversioux
Would you say its the whole assembly or just the bulb?
Old Jun 16, 2011 | 11:28 PM
rbrumm's Avatar
rbrumm
Everthing I have read says the assembly may be bad. I have also been told that if the voltage through the bulb is low it will throw the light. Seems a little sensitive to me. You could pull the bulb and see if there is some corrosion.
Old Jun 17, 2011 | 04:48 AM
scwpd's Avatar
scwpd
had about the same thing happen on my cvpi the bulb had came loose just put in a new one and fixed it. now on my ram the light out came on and i looked at all my light and they worked ended up being a break light that was out but if you need a new assembly i would check rockauto.com
Old Jun 17, 2011 | 02:21 PM
Calvert's Avatar
Calvert
Same thing happened to me while driving from Chicago to Phoenix...the beeping drove me crazy so i stopped at a dealership and had them fix it real quick. they put in a new "panel" for lack of a better word right now, that all the bulbs plug in to. Apparently it is a known issue amongst rams. Took them about an hour and cost me like $120.
Old Jun 17, 2011 | 10:59 PM
Geezir's Avatar
Geezir
I had this problem. New aftermarket circuit board cost me $30 and a 1 year warranty on it. 5 minutes in driveway and the problem was fixed.
