Replacement Tires
Old Jun 19, 2011 | 09:49 PM
Libtech's Avatar
Libtech
Default Replacement Tires
I have a 2005 Ram 1500 SLT 4x4 short box quad cab. Bought it second hand and it has 265/70r17 on it right now. Have to replace the tires, would there be any reason to drop down to OEM size of 245/70r17? Only thing I can think of is gas mileage, but if its negligible I would rather keep the bigger looking tire. If could get 3mpg out of it I would maybe consider it.
Some of the online sites say the 265 is an optional size anyways so thought I would post and see what people think.
I had Bridgestone Dueler A/Ts on and I must say they didnt last very long.
Old Jun 20, 2011 | 01:03 AM
mattwv88's Avatar
mattwv88
You will see 0 mpg change in that. If I was you I would be moving up in size. I got the same truck with 295/70/17`s. With my mods I get a consitent 16mpg in the hills of WV.
Bridgestones suck all together. What kind of driving do you do? I love my Nitto terra grapplers.
Old Jun 20, 2011 | 04:49 AM
Flyman1981's Avatar
Flyman1981
I had the 20s so its not quite the same, but I just got rid of the stock Goodyears at 35k miles. I was getting 15.5 overall when i was easy on it and mid 16s for all highway. I think they wore pretty well considering I wasn't easy on them. They wore evenly and only started to slightly cup after 30k miles.
Do you haul, go offroad or just street, see snow, want a meety tire, quiet, cheap? Got lots of questions to answer before you should pick out a tire.
Old Jun 20, 2011 | 04:51 AM
Flyman1981's Avatar
Flyman1981
I agree with Matt, I have heard great things about Nittos. I just bought the trail grapppler because I want the look, off road performance and my truck isn't my DD.
Old Jun 20, 2011 | 07:02 AM
MikeHTally's Avatar
MikeHTally
I went from 265/70 Dueler ATs (45K+) to a set of 285/70 Bridgestone Revo2s. 245s will improve your gear ratio and give you a bit more jump off the line. No change of tires will give a 3 mpg improvement. You could do many, many things which might provide a cumulative increase of that much, but it isn't likely.
Old Jun 20, 2011 | 09:20 AM
Libtech's Avatar
Libtech
I dont do much offroading to warrant extra cash on a more offroad tire and loose any hiway performance. I am 95% highway, hunt in the fall for a bit but thats about it.
I tow a trailer in the summer, but need a good allseason for winter as we have some very harsh winter conditions. As usual, dont want to break the bank, just had a kid.
BTW I am in Canada, prices suck here. I have seen these tires on for $120.00 in the states, oh well.
Old Jun 20, 2011 | 11:36 AM
Libtech's Avatar
Libtech
I found a set of Nitto Dura Grapplers for $1200 including a 4 wheel alignment. Seems to be the best price on tires around here that I can tell.
Thoughts on the NIttos?
Other than that its BFG Rugged Terrain TA for $1250, but its a 6 ply. The NIttos are 4 which is all I should really need, only tow a light trailer. Or there are a set of Hercules Tera Trac A/W for $1150.00.
Old Jun 20, 2011 | 11:48 AM
Cthulhu's Avatar
Cthulhu
I got BFG KO/TAs in Canada for $1100...
You should be able to grind the guys in the USA for cheaper than I got them for!
Old Jun 20, 2011 | 11:49 AM
Brandon Anderson's Avatar
Brandon Anderson
Check out the Cooper Zeon LTZ. ~$180/tire
Old Jun 20, 2011 | 01:19 PM
mattwv88's Avatar
mattwv88
From what your saying I think the Nitto Terra grapplers would be great for you because they are awesome in the snow. We have bad winters here as well and I never had any trouble. I have never heard anything about the nitto`s you mentioned but I looked them up and I don`t think they would be as good in the snow as the terra grappler. Maybe someone here has had them before but they just don`t have a good looking snow tread to me. As for the Hercules if your going to pay that much just go alittle more and get a much better tire if you can swing it.
