03 1500 Trans hard down shifting
Old Jun 23, 2011 | 02:16 AM
dragon_32's Avatar
dragon_32
Default 03 1500 Trans hard down shifting
I have an 03 1500 QC with 26000 miles on it. I just got the truck from a dealership. The truck sat for a long time in a barn and wasn't used. Everything works great on the truck, but it's shifting hard right before coming to a stop. It also shifts hard into second gear if you get on her from a stop. Does anyone know what might be causing this? Is there a fix without going to a dealer? I have a warranty but it sounds like most of the dealers want to look at it and run all sorts of test that will cost me before a repair is made.
Old Jun 24, 2011 | 09:27 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
How many miles have you put on it since you got it? Try resetting the PCM and after that i would drop the pan and inspect everything and change fluids and filters.
Welcome to the site
Old Jun 24, 2011 | 09:44 AM
nateroach's Avatar
nateroach
I agree with weed. reset the PCM by pulling the battery terminals off and touching the cables together for ~20 sec. them check trans fluid levels. if your still having problems time for a pan drop and fluid swap + filters.
Make sure you read the DIY in the FAQ section on the trans filter replacement to make sure you get the filters and associated o ring seated properly so you aren't dropping the pan again 3 days later to fix it. it's a dirty job the first time you drop the pan, and it usually doesn't get any cleaner (unless you get a different pan or install a plug) so do it right the first time.
nateroach
Old Jun 24, 2011 | 06:02 PM
dragon_32's Avatar
dragon_32
Thanks guys!! The PCM reset seems to be working great. I'm about to do a fluid and filter change this weekend.
Old Jun 25, 2011 | 10:18 AM
John  M's Avatar
John M
Wouldn't it have been reset after sitting for years in a barn?
So much for my "low mileage" 03 at 76k!
