Old Aug 14, 2015, 07:25 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Transmission Diagnostic Guide
Print Wikipost
Transmission Fluid Change help
Old Jul 5, 2011 | 03:14 AM
dragon_32's Avatar
dragon_32
Did you have some one flush it for you? If you unhook the lines and do it yourself you aren't flushing anything. You are using the trans normal fluid path to replace the old fluid, not forcing it in a direction it wasn't ment to go and forcing gunk into other areas.
Old Jul 5, 2011 | 03:18 AM
USMC-Mortar-Man's Avatar
USMC-Mortar-Man
Originally Posted by scwpd
do your self a favor and do a search and look at all the people having problems after having a trans flush my self included. some people think it is due to faulty filters.
Ok what is your point???
Old Jul 5, 2011 | 03:33 AM
dragon_32's Avatar
dragon_32
I used the same method as in that thread I posted earlier. Disconnect one of the lines and see if fluid comes out when you start the truck. I want to say it was the top line, but hell I can't even remember what I had to eat for breakfast 8 hours ago. You can tell when all the old fluid is out cause it will look like new fluid.
Old Jul 5, 2011 | 03:58 AM
USMC-Mortar-Man
Ok very. And the lines are connected to tranny correct. I am not the brightest could you explain to how to disconnect the and where is located? could you explain it to me barney style
Old Jul 5, 2011 | 04:30 AM
dragon_32's Avatar
dragon_32
http://www.youtube.com/watch?v=MsdPAadc9fY Here is a video on a car, but the same basic info on the truck. Don't pay attention to the drain plug and all the other crap. Just watch the flushing part. You will need a 3/8 disconnect tool to remove the line. You can get it at any parts store. Don't ever let your fluid run to low.
Old Jul 5, 2011 | 05:03 AM
USMC-Mortar-Man
Thank you so much. What rank are you and where are you stationed ?
Old Jul 5, 2011 | 05:44 AM
dragon_32's Avatar
dragon_32
E-7, currently at FT. Eustis, VA.
Old Jul 5, 2011 | 02:57 PM
USMC-Mortar-Man
I got out as a E-5 I was stationed at Camp Lejeune North Carolina. I didn't like the south
Old Jul 5, 2011 | 03:32 PM
scwpd's Avatar
scwpd
My point is even doing it your self you are still doing a flush and people are having problems with the converter draining out after sitting for a period of time some people have found that there are bad batches of filters and there is also a o ring that you have to put in place first before you put on the filter
Old Jul 6, 2011 | 02:21 AM
USMC-Mortar-Man
Ok can you explain to me the process with the o ring?
