Old Aug 14, 2015, 07:25 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Transmission Diagnostic Guide
Print Wikipost
Transmission Fluid Change help
Old Jul 6, 2011 | 02:34 AM
  #21
scwpd's Avatar
scwpd
I believe its for the spin on filter you need to actually push it up in the hole and then put the filter on other wise it will distort the o ring also there are just bad filters I believe something about not crimping the seal right when they are made and letting the fluid drain from the converter one post I read says filters with out the ab sufix are suposed to be the good ones but people are still having the problem
