2005 1500 QC 4x4 Lower Ball Joints are these replaceable?
Old Jul 8, 2011 | 07:57 PM
Gijohnny23's Avatar
Gijohnny23
Angry 2005 1500 QC 4x4 Lower Ball Joints are these replaceable?
So I went to autozone got some lower ball joints, not because mine are bad, just the grease covers were split. After reading through the book it says some are not replaceable w/o replacing the whole lower A-Arm. Has anyone run into this problem? Here's a picture let me know what ya'll think. 2005 1500 QC 4x4
Old Jul 8, 2011 | 07:58 PM
Gijohnny23's Avatar
Gijohnny23
By ya'll think, I mean are these the replaceable kind?
Old Jul 8, 2011 | 09:36 PM
dirtydog's Avatar
dirtydog
Moderate User
Should be pressed in and should be able to do either or.
HERE for controll arm assly.
HERE for BJ's
Dont think you can beat it out with a hammmer because you'll ruin the control arm.
Old Jul 9, 2011 | 07:08 PM
Gijohnny23's Avatar
Gijohnny23
Has anyone done these on an 05? cause even with the big c clamp from auto zone I can't get it out, the top looks like it has a cap that is pinched on in three 3 place. Also is it possible to just order the rubber boot?
Old Jul 10, 2011 | 07:01 AM
abarmby's Avatar
abarmby
Two methods usually secure the lower BJ into the control arm that I'm aware of.
1) There is a snap ring fitted into a groove running around the top of the BJ. This clips into place and must be removed before pressing out the BJ.
2) Sometimes the top of the BJ has 3 or 4 crimps/tabs twisted into the top. These must be straightend by using a chisel to beat them strait to allow the BJ to be pressed out.
Here's a link to a "how to".
Snap ring removal:- http://www.youtube.com/watch?v=r0jzw...eature=related
Pressing out:- http://www.youtube.com/watch?v=IVluV...feature=relmfu
Pressing in:-http://www.youtube.com/watch?v=0z-gCDC8oOw&NR=1
Hope this helps?
Al.
Old Jul 10, 2011 | 12:47 PM
dirtydog's Avatar
dirtydog
Moderate User
Nice vid's.
Old Jul 10, 2011 | 02:54 PM
Gijohnny23's Avatar
Gijohnny23
So the chisel method isn't working, and maybe it's just I can't see it in my imagination are the control arm slots for the ball joint flush on the top and bottom? Cause as of right now I have 3 holes drilled in the top and part of the lip ground down. I just don't want to grind too much. OR can I just ground the crimped lip down flush with the control arm?
Old Jul 11, 2011 | 10:24 PM
Gijohnny23's Avatar
Gijohnny23
Ok just an update I pulled the lower control arm and took it too sears, with the big c clamp, and a impact gun and about 30 minutes they finally popped it. Just so you all know it's $135 for them to do one side, Dodge country in killeen wanted $445 a piece.
Old Jul 12, 2011 | 04:24 AM
abarmby's Avatar
abarmby
Gijohnny23.
Did you inspect the balljoint when they removed it??
Was it a snap ring or the "tabbed" balljoint the you have to use a chisel on it?
PS....$135 to just press it out, or did they put the new one in as well, or anything else?
Al.
Old Jul 18, 2011 | 11:16 AM
Gijohnny23's Avatar
Gijohnny23
They're just pressed out, using the c clamp and an impact gun. it is $135 if you drive your vehicle there and say fix this. So not too bad for the labor of taking some of that stuff off.
