Annoying interior squeak
Old Jul 13, 2005 | 12:30 PM
ohlarikd's Avatar
ohlarikd
Default Annoying interior squeak
Just picked up a 05 2500 QC 4x4 - it is certainly light years better than my old 95 Ram. Of course, when everything is good, I still have to obsess and find something wrong, and I have noticed a very annoying interior squeak. Sounds like somewhere from the center console to the front passenger area. I haven't been able to pinpoint it, its always hard. Anyone have any experience with squeaky Ram interiors? I want to bring it in to the dealer, but if I could get some ideas where to look, that would be great!
The employee plan plus $3000 made this an easy purchase. The Hemi crushes my old 318, which had 220hp back in 95. Great truck.
Derek
Old Jul 13, 2005 | 12:49 PM
BIG HORN RAM MAN's Avatar
BIG HORN RAM MAN
Default RE: Annoying interior squeak
I have an 04 1500 and had a squeak like that finaly found it under the passenger seat where the jack is stored. If you move the seat to a certain position the squeak will stop at least it did for me. hope you find it I know how annoying it can be good luck.
Old Jul 13, 2005 | 01:02 PM
ohlarikd's Avatar
ohlarikd
Thanks for the clue - I will try to mess with the jack and seat at lunchtime. Yes - once I hear a squeak, thats ALL I hear. Its a disease. Thanks for the understanding!
Derek
Old Jul 13, 2005 | 01:07 PM
bpunk360's Avatar
bpunk360
my 05 2500 hemi qc 4x4 was squeaking b/c the 4 wheel drive shifter was rubbing a rubber grommet under the boot..... check that
Old Jul 13, 2005 | 04:57 PM
Ram05guy's Avatar
Ram05guy
I had the same problem that bpunk360 had. I have found if you shift in and out of 4H the squeak goes away for a while. Took about a month to come back.
Old Jul 13, 2005 | 05:22 PM
rob_net's Avatar
rob_net
wow, finally, 2 weeks with this issue in my ram 2500 2x4 2005
"found it under the passenger seat where the jack is stored. If you move the seat to a certain position the squeak will stop at least it did for me. "
I try
thanks big horn
rob
Old Jul 13, 2005 | 06:26 PM
ohlarikd's Avatar
ohlarikd
Well, I tried the Jack - nope. Then I thought maybe the seatback was making noise, so I held it in place - nope. Now I am looking at the Glove Box as a possible cause, so I driving with it open. Haven't heard the squeak in a while, but I've been fooled before, it may come back.
I have also been very suspicious of the 4WD console as well, I've been holding it with my hand, but the squeak is still heard. Then again, I can't hold it tight enough. Maybe I need to remove the cover and shoot some WD40 or lithium grease on the rubber parts...
bpunk360 - I am not in at my truck right now, but I assume the rubber boot comes off with some screws, or is there a trick? Thanks!
Derek
Old Jul 13, 2005 | 08:26 PM
bpunk360's Avatar
bpunk360
honestly no clue i never took it off it went away by itself... when it was squeaking if i put some slight pressure on the shifter pulling it towards the driver side it would go away.... i did feel a litle play in the shifter from left to right was planning on checkin it out but it went away by itself.... but yea that would be my guess is that the boot comes off w/ the cover
Old Jul 15, 2005 | 04:08 PM
ohlarikd's Avatar
ohlarikd
Despite that this might jinx me, I think I found the squeak. I put four little felt pads on the 4 rubber feet on the glove box. The squeak is gone. That glovebox is so flimsy and loose, I am not sure how it got designed that way.
Hopefully it will not reurn. Thanks!
Derek
Old Jul 15, 2005 | 04:41 PM
eltupac's Avatar
eltupac
Not be **** about it and jinx someone else with this, but I also hear a squeak once in a while. Mine comes from the steering column. When I adjust the tilt, it leaves it loose somehow, so when I go over bumps or shift I will hear it. Dont know, but that is minor compared to my manual transmission rattle noise. New 2005 RAM go figure.
