will this thermostat help
Old Jul 11, 2011 | 10:59 PM
mlodzik13's Avatar
mlodzik13
Default will this thermostat help
hey guys. so ive recently been having some stalling issues with my truck. 05 1500 with the hemi in it and i read that you can put a 180* thermostat in it to make it idle higher. ive cleaned the throttle body and didnt really help at all.
http://www.jegs.com/i/JET+Performanc...10183/10002/-1
this was the thermostat that i found. is there any other options or is this my best bet?
thanks guys
Old Jul 12, 2011 | 06:26 AM
HammerZ71's Avatar
HammerZ71
The theory here is that the cooler temp richens the mix a bit and the PCM will bump idle a bit because it thinks the truck is still not up to temp. Depends on why the truck is stalling, but if couldn't hurt to try one. That's the one I've been running for about five years now...
Old Jul 12, 2011 | 02:55 PM
lxman1's Avatar
lxman1
Site Moderator
You need to find the actual problem, not band aid it. I would try cleaning the throttlebody first.
Old Jul 12, 2011 | 03:45 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Agreed. Find should clean the TB and do other maintenance related items like plugs, vacuum lines, ECT
Old Jul 13, 2011 | 02:13 AM
mlodzik13's Avatar
mlodzik13
i have cleaned the throttle body and put new plugs and wires in it as well. i havent changed the egr valve yet.. should i look at doing that first before the thermostat.
Old Jul 13, 2011 | 08:15 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Front O2 sensors could also cause it as well as low trans fluid
Old Jul 13, 2011 | 10:39 AM
mlodzik13's Avatar
mlodzik13
alright sounds good. i got the day off today so im gonna go through and check everything again and see if i maybe over looked something. thanks for all the help
