possible electrical issue....
Old Jul 15, 2011 | 05:59 PM
BadHab1t's Avatar
BadHab1t
Default possible electrical issue....
odd for me as im very elecrically inclined....lol....
so i jump in the truck this morn and my dome/puddle lights arent on, i flick the switch to make sure my switch wasnt all the way off, and nothing....
so after work today i checked the fuses, all of them and 18 would be labelled interior illumination, all good... my map lights work, hmmmm, so i trace the wires from dome to my t-tap where i tapped in so when i open my doors the puddle lights come on, which is behind the a-pillar, everything is secure, but no power to the t....i know my test light is grounded good as i checked another power source with it grounded in the same place, grounds on puddle lights are tight and look good, dome light bulb tested in working order, i wish i had brought my multimeter home with me from work.....does anyone have any idea? im at a stand still which is really weird for me.....where is the door plunger that tells the interior lights to come on... or the sensor that does when i hit my fob....
Old Jul 15, 2011 | 06:43 PM
Gone Fishin's Avatar
Gone Fishin
It appears that the interior lights are fed from and integrated power module in the instrument cluster.
Run an instrument cluster diagnostic---hold the trip reset in while turning the key to on, if I remember right----should see some kind of a "C" code
Old Jul 15, 2011 | 09:28 PM
BadHab1t's Avatar
BadHab1t
ill give that a try i dont have anything to lose...thanks
Old Jul 16, 2011 | 03:24 PM
lxman1's Avatar
lxman1
Site Moderator
The switch is integrated into he door latch.
