Dodge Ram 1500 charging issue
Old Jul 21, 2011 | 08:31 PM
MikeHTally's Avatar
MikeHTally
Voltage drops when amps increase. The voltage regulator will call for more volts as the current draw increases. With only the minimum draw, alternator output should be 13.8VDC to maybe 14.6VDC If it isn't the alternator, it's the battery.
Old Jul 21, 2011 | 09:11 PM
lxman1's Avatar
lxman1
Site Moderator
Originally Posted by joe cannon
No I meant the amp output..something else that the truck does that may or may not be related is,,,,when you turn the ignition key to acc the power windows work but the windshield wipers do not...It that not backwards?
That is normal, the wipers only work with the key in the run position.
Old Jul 21, 2011 | 09:14 PM
lxman1's Avatar
lxman1
Site Moderator
Volts = power
Amps = amount of current being moved.
With high amp draw at low rpm, the voltage will drop.
