which Radiator Cap to use on my ram hemi
Old Jul 29, 2011 | 04:44 AM
adventurer's Avatar
adventurer
Default which Radiator Cap to use on my ram hemi
i have an aftermarket 2cm shorter radiator on my 2006 hemi so
Which rad cap is better 16 LBS or 18 LBS and what is the difference between the two ?
Old Jul 29, 2011 | 10:29 PM
lxman1's Avatar
lxman1
Site Moderator
Just use the one that it calls for. 16 should be fine. It just takes 2lbs more before opening the 18 over the 16. An 18lb will find a weak spot in the cooling system before a 16 will.
Old Jul 30, 2011 | 03:01 AM
adventurer's Avatar
adventurer
Thanks , so i will keep using the 16lbs
Old Jul 30, 2011 | 04:20 PM
lxman1's Avatar
lxman1
Site Moderator
Wise choice.
Old Jul 31, 2011 | 09:28 AM
adventurer's Avatar
adventurer
what is the best way to get the air pocket out from the radiator ?
Old Jul 31, 2011 | 07:51 PM
lxman1's Avatar
lxman1
Site Moderator
I just run them without a cap until it quits burping air.
