Need balljoints
Old Jul 30, 2011 | 03:09 PM
TexasRam01's Avatar
TexasRam01
Default Need balljoints
I tried doing a search and found no real information. I have recently had to relocate to an apartment, all my tools, including my jack are in storage and I think I need to replace my upper balljoints. I called down to Firestone and they say that you have to replace the entire upper control arm.... I have an '08 1500 w/ 4.7. I look around on-line and you can purchase just the ball joint, but is this going to be a waste of time. I'm already a little irritated at the fact I am replacing ball joints at 80k miles, but Firestone now wants $900 plus an alignment to replace upper control arms / ball joints. Has anyone else done this?
Old Jul 30, 2011 | 04:01 PM
HammerZ71's Avatar
HammerZ71
Some guys swear they don't come off. I've never done my own, they are still in great shape but I did a friends '05 and the uppers came right off with a pickle fork. No problem pressing the new one on either, just used a press borrowed from Advance.
And as far as having to replace ball joints at 80k miles, don't be a hater, I had a Furd truck in the mid '90s couldn't go 30k without needing them...
Old Jul 30, 2011 | 08:05 PM
Cthulhu's Avatar
Cthulhu
I'm assuming the 1500 and 3500's are different, however I JUST had my 3500's BJ's replaced without having to replace the control arm. They had no issues pulling them. I installed MOOG's.
Old Jul 31, 2011 | 11:45 PM
Brandon Anderson's Avatar
Brandon Anderson
The parts list for our 2008 1500 (4x2 or 4x4) does not specify an upper balljoint, only the entire upper assembly, whereas there is a part number for the lower balljoint. Also, the '06-08 UCA is significantly different than the rest if the 3rd gens. Looking at mine when I installed the spindles, the balljoint does not appear to be pressed in, but rather it looks to be a part of the control arm. $900 sounds like a bit much just to swap out the control arms, but I do not think they are lying to you.
Old Aug 1, 2011 | 12:05 AM
Brandon Anderson
You would be correct in assuming that they are different. Even in '08, the 2500, 3500 and "1500" megacab still used the same UCAs as the pre-'06 1500. They could be used on either the left or right-hand side interchangeably, and the balljoints (while not specifically stated anywhere that I can find) appear to be replaceable, as Hammer stated earlier.
Old Aug 1, 2011 | 05:37 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
1500s must replace the entire assembly for the upper. Only the lower BJ pops out
Old Aug 2, 2011 | 06:38 AM
ccm182's Avatar
ccm182
Ok I am confused. I have an 08 1500 quad cab 4x4 with the 5.7. I went to advanced and bought uppers and lowers and they are just the ball joints. Their computer did not show a complete assembly and rock autos site didn't show a complete assembly either. I don't know if I should take these uppers back and try to find a complete assembly or not? I would really hate to start to get into this project and not have the right parts.
Old Aug 2, 2011 | 06:47 AM
Brandon Anderson
Looking at rockauto.com, I see ONLY full assemblies under suspension > control arm. There is only one part listed under suspension > balljoints for "upper", and they appear to be for a megacab, which uses a different UCA. Again, even if you could get the upper balljoint out, I don't know how you would get a new one back in.
Old Aug 2, 2011 | 06:55 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
What is the P/N and brand you bought for the upper BJ? Look them up on the manufactures site and see what they are listed for.
Old Aug 2, 2011 | 07:01 AM
ccm182's Avatar
ccm182
oh I was just looking at suspension>ball joints. I couldn't tell how you knew if they were for the mega cab or not. I seen some that 8 lug which I believe is mega cab but some that said 5 lug were also listed.
