Where are my grease fittings located?
Old Aug 3, 2011 | 06:12 PM
shadesters's Avatar
shadesters
Default Where are my grease fittings located?
I have an 05 Ram 1500 2WD 3.7L, and I was wondering where I would see the fittings that I should add grease to... I know my U-Joints don't have them, but are there other areas that I should hit up with some grease, since I do not take my truck to shops anymore?
Old Aug 3, 2011 | 07:03 PM
Rookie1500's Avatar
Rookie1500
If your truck is anything like mine, you wont have greaseable stock parts.
But there are several locations that i know of that need grease.
Tie rod ends (both front tires, 1 per tire)
Ball joints (both front tires, 2 per tire)
U joints (should be 3 along the drive shaft)
Please correct me if i am wrong in any of this.
Old Aug 3, 2011 | 07:54 PM
Marx's Avatar
Marx
ya no grease-able fittings on theses trucks
totally agree, if that list is what should have grease fittings lol
Old Aug 3, 2011 | 08:04 PM
bigdaddyII's Avatar
bigdaddyII
Only 2 u joints on my truck though. And every one of the things you listed (except 3rd u joint lol), get a healthy dose of grease at every oil change. Though not the stock parts, replaced with part that have grease fittings when they wore out.
Old Aug 3, 2011 | 08:24 PM
HammerZ71's Avatar
HammerZ71
Yep, I have Moog tie rod ends. When the ball joints start acting up, they'll be replaced with greasable ones too...
Old Aug 4, 2011 | 12:21 AM
Rookie1500's Avatar
Rookie1500
I stuck moog tie rod ends on my truck a few months back. Got them from http://www.rockauto.com/ and shipped to my door for less then $100.
My plan is the same as Hammerz. Change them as they go... except the u-joints. I think i will be dropping my rear end soonish and might as well do those then.
