brake and abs lights
Old Aug 13, 2011 | 08:49 PM
vivini's Avatar
vivini
Default brake and abs lights
just replaced my heater core, and after putting dash back together i turned truck on and my break light comes on blinking, after that my abs light turns on..
truck wasnt doing that till i removed dash, is it possable to have pinched a wire some where?. I was wondering if theres a wire harness any where around my dash that could have been pluged in incorrectly or somthing.
Old Aug 14, 2011 | 12:22 PM
06Dak4.7Silver's Avatar
06Dak4.7Silver
I'm assuming you forgot to plug something in..I know its annoying but you might have to remove the dash again
Old Aug 14, 2011 | 12:52 PM
dirtydog's Avatar
dirtydog
Moderate User
I'd try crawling under the dash before removing it. Most of those connections are behind the steering wheel area.
Good Luck
Old Aug 14, 2011 | 04:43 PM
vivini's Avatar
vivini
brake switch under dash had to be re adjusted fixed
Old Aug 15, 2011 | 08:20 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
THX for posting the resolution
