Does anybody have remote radio controls?
Old Aug 28, 2005 | 12:19 AM
Chet Ubetcha's Avatar
Chet Ubetcha
3rd Gen Ram Moderator
Default RE: Does anybody have remote radio controls?
I think the Infinity system comes with the steering wheel controls. I've got them in my truck, and I can't believe I never knew what I was missing!
Old Aug 28, 2005 | 11:53 AM
thundersteel's Avatar
thundersteel
The Infinity system does not come standard with the steering wheel remote controls--at least mine didn't. According to the Dodge website, they are $75 option, regardless of whether you have the Infinity system or not.
Old Aug 28, 2005 | 11:57 AM
Chet Ubetcha
Well ok then...I stand corrected.
It's $75 I would gladly spend though, if I knew it were an option.
Old Aug 28, 2005 | 02:06 PM
vipersforsale's Avatar
vipersforsale
man you guys must have some short arms to make such a big deal about a little stretch to the radio... I have a remote for mine and never use it because its easier to just turn the **** than to fiddle with the remote. I barely have to lean over to get to it and I drive with my seat all the way back and slightly reclined at that. Maybe I am just part gorilla, I dont know!
Old Aug 28, 2005 | 07:20 PM
Chet Ubetcha
Ihave no problem with the reach, it's just very convenient...and safe...to have the controls right there on the back of the wheel.
Old Aug 30, 2005 | 01:30 PM
AZFlyingDiver's Avatar
AZFlyingDiver
According to this (from TruckTrend), trucks without the factory option are not pre-wired for the steering wheel controls (but you never know - it seems the best way is to get in there and look, hassle as it may seem)... Anyway, some good info here for if/when you do...
Q:I need to replace my 2002 Dodge Ram 1500's steering wheel, and the current wheel doesn't have the remote control for the radio switches. My questions: First, how difficult is it to replace the actual steering wheel with respect to the airbag? Second, are the remote radio controls already wired and just need to be connected or would there be more to it than that?
A:First, and most important, the airbag system must be fully disabled by disconnecting the battery and allowing two minutes for the system to discharge. This will prevent accidental deployment and serious injury. That said, the wiring harness for the airbag and remote radio controls is connected through a "clock spring" located behind the steering wheel on the steering column. The clock spring is a wound-up group of wires that allows the steering wheel to rotate back and forth without breaking the wires. If your Dodge Ram didn't come from the factory with the remote radio option, the appropriate wiring wasn't installed and adding a steering wheel equipped with radio control switches isn't going to make it work. Replacing the steering wheel involves the removal of the airbag mounting screws, disconnecting its electrical connector, and loosening the steering-wheel retaining bolt before installing a special steering-wheel puller tool. Be sure to have the wheels straight ahead and the steering wheel centered before removal. Then mark and reinstall the steering wheel in exactly the same spot. This will keep the clock spring centered and prevent a future break in the airbag wiring.
Old Aug 30, 2005 | 02:49 PM
Drew's Avatar
Drew
you guys must have some short arms. . .Ive got a QC, got the seat slammed back, I drive a 6spd, and have no problems hitting the radio buttons
Old Aug 30, 2005 | 03:51 PM
thundersteel
This may be true for the 2002 model, but, as I stated previouosly, mine WAS pre-wired, and my "new" controls work!
Old Aug 30, 2005 | 11:39 PM
Silver Eagle's Avatar
Silver Eagle
I have one for my PT Cruiser. But it's easier not to use it.
Old Aug 31, 2005 | 02:28 AM
BlueHemi's Avatar
BlueHemi
ORIGINAL: thundersteel
thundersteel - what year is your truck?
