03 Ram 4.7L A/C
Old Aug 30, 2011 | 09:10 PM
BTTHEUS77's Avatar
BTTHEUS77
Default 03 Ram 4.7L A/C
my 03 dodge ram 4.7L blows heat when it sits still but when im moving it starts to work normal do anyone know what the problem is????
Old Aug 30, 2011 | 10:18 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
common issues. lots of threads on it. likely the condenser fan isnt running as it should be. so the only time air gets blowed across the fins is when you are moving. make sense? so check your fuses first. then jump 12v to the fan to test it and replace it if it doesnt work. do a thread search on here on how to replace if needed
Old Aug 31, 2011 | 03:11 PM
BTTHEUS77's Avatar
BTTHEUS77
thats the fan alonng side the radiator right?
Old Aug 31, 2011 | 08:38 PM
lxman1's Avatar
lxman1
Site Moderator
Yep, on the condenser on the driver side.
Old Aug 31, 2011 | 11:53 PM
BTTHEUS77's Avatar
BTTHEUS77
thanks guys the old one was shot i replaced it and it works like a charm
Old Sep 2, 2011 | 10:22 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
glad you got some 100% working ac now
