3rd Gen Ram Tech2002-2008 Rams: This section is for TECHNICAL discussions only, that involve the 2002 through 2008 Rams Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
Hello forum people. I found this part hanging under the dash near the steering column and cannot figure what it is or where it goes. Any Ideas? only issue truck is having is with cruise control only working for 30 seconds at a time. might be related. any help is definitely appreciated. truck is 2004.5 ram 3500
Reason: adding truck
I agree it looks like a clutch or brake switch, which would also make the CC malfunction.
If it is your brake switch, it would also make your brake lights not work, so you might wanna get that checked out LoL
If it's your clutch switch, you would likely be able to start the truck without using the clutch.
UPDATE I got ahold of a friends alldata last night and it turns out that it attaches to the shifter cable. It is a brake park position lock switch. Keeps my shifter in park position until I hit the brake. Thank you to all that tried to help.
This begs the question: how'd it get down there? LoL
