dual relay wiring
Old Sep 10, 2011 | 11:11 PM
theice's Avatar
theice
Unhappy dual relay wiring
can anyone give me a wireing diagram to wire up two relays to a single e fan on a dodge ram 4.7 1500 thx in advance
Old Sep 11, 2011 | 12:53 AM
lxman1's Avatar
lxman1
Site Moderator
Why 2 relays? 2 speeds?
Old Sep 11, 2011 | 01:17 AM
John  M's Avatar
John M
Are you wanting to split the amperage between two relays to power a single speed of the fan, or do you need to power two fan speeds?
Old Sep 11, 2011 | 08:17 AM
theice's Avatar
theice
want to split the amperage between tow relays for a single fan also my controller only has two wires one for power the other to the fan to power it when it reaches the set temp and also the controler is adjustable thx
Old Sep 11, 2011 | 01:32 PM
John  M's Avatar
John M
Both relays: (pins are numbered)
86 - ground
85 - +12v from fan controller
30 - battery (tie wires together to a single fuse appropriate for the fan's draw)
87 - to fan (tie wires together to single fan wire)
Old Sep 11, 2011 | 03:13 PM
theice's Avatar
theice
thx for your help it worked fine
