2005 ram rear end
Old Sep 12, 2011 | 06:58 PM
mattg34's Avatar
mattg34
Default 2005 ram rear end
have a question i hope someone can help me with. i have a dodge ram st 1500 reg cab with 3.55 limited slip gears. i want to upgrade to 4.10"s or lower by swapping rear ends instead of a gear change. what year rear ends will fit my truck? thank you!
Old Sep 12, 2011 | 07:00 PM
SLT8's Avatar
SLT8
9.25 directly.
SRT-10 Dan 60 w/ some modifications.
You will like the lower gears. With my tire/rim setup i got a good noticeable difference when i went from 3.55's to 4.10's.
Old Sep 12, 2011 | 10:26 PM
mattg34's Avatar
mattg34
Originally Posted by SLT8
9.25 directly.
so any year dodge ram with a 9.25 rear end will work? sorry new to this and didnt quite understand what u meant. id like just to find a rearend with the gear i want in it and swap them.
Old Sep 12, 2011 | 10:29 PM
Marx's Avatar
Marx
3.92 is the tallest you can go with a factory axle swap
Old Sep 13, 2011 | 11:20 AM
SLT8's Avatar
SLT8
9.25 from a 3G 1500 will be a straight swap but like the post above 3.92's is the tallest (lowest) gear available from the factory.
That said i now think that 4G 1500 R/T has 4.10's as a optional gear however i am not sure how hard it is to get a used axle.
