Tip Start
Hi everyone,
So I emailed Dodge the other day asking for my build info. They responded quickly and gave me everything, thank you Dodge. So they listed a couple of things, 1. Tip Start --- what is that? and 2. 9.25 LD Axle--- What is that?
Any help would be helpful.
Thanks
James
Thanks
James
what year is your truck?
tip start means that you don't need to hold the key in the start position for the truck to start.. basically next time you start it get in and turn the key to start but then let it go back to ignition right away.. the truck will crank and start like normal as if you were holding the key... been around for awhile on lots of cars..
9.25 inch rear gear rear differential with Limited slip differential... simple stuff.
I found it here on the forum. It was a link to Dodge and you just fill in the info. Sorry, I really don't remember where it was.
