stumped with p0440 and p0441 plus 2 codes?
Old Feb 24, 2012 | 03:23 PM
broncoremy's Avatar
broncoremy
Did you find something and fix it to get rid of the other codes?
I think (?) low voltage on the O2 sensor means lean, so the engine controller is throwing a higher ratio of gas to try and correct it. Have you checked TB, plugs, etc?
Old Feb 24, 2012 | 05:35 PM
wink2873's Avatar
wink2873
low voltage means its probably just going bad and getting lazy... which means it wont adjust the fuel ratios correctly.... which would explain why your getting bad mileage.
