Rear shock replacement
I am doing my rear shocks on my 06 4x4. The bottom nut/bolt are both 21mm, what is the top bolt? Is it 21mm also? What is the best way to get to it cuz the frame rail is in the way... a ratchet with an extension?
Also, it looks as though the top nut is "captured" so you shouldn't need hold it, correct?
I have an '05, 4X2 and did mine a few days ago. mine were 21mm for both the top and bottom. It "looked" as if it was captured, but it wasn't. On the drivers side, I had to lower the spare out of the way, held a wrench to the nut while my buddy cranked on the bolt, through the wheel well using a 4in extension. Break free or WD-40 the day before really helped. But again, mine is 2wd...hope this helped and good luck!
Did it today on rear. Not fun for 4 little bolts. Bad news is I have to redo it all over because I either didnt get the new rubber gromets with order or forgot to reuse old ones. Used a 15 mm racheting wrench on my model. What shocks you using. Jumping on the back end after replacement is amazing now. Used KYB Mono shocks.
