Old Aug 13, 2015, 05:55 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Interior Guides
Print Wikipost
Remove overhead console light covers w/sunroof
Old Oct 26, 2011 | 10:47 AM
bradguin's Avatar
bradguin
Awesome, thanks a lot man. Ill test her out tonight after work
Old Nov 17, 2011 | 07:55 PM
RamMan05's Avatar
RamMan05
had the same problem, ive had no luck getting them up, just messed up the plastic around it, seems like the lense is too big to pry out without destroying the plastic, hopefully it will work after reading through this
Old Mar 9, 2015 | 01:36 PM
cwwhip's Avatar
cwwhip
Default Updates?
I have that exact same ceiling console and need to take it down. Did you end up getting it off? How? Help please. ALL the online helps are geared toward the other ceiling consoles.
Old Mar 11, 2015 | 10:57 PM
g8rduc's Avatar
g8rduc
The hole in the front of the "console" has a phillips head screw. Take that out, then on each side of the lamp area are clips holding the whole assembly. Pull straight down on each side. You don't remove the lenses. Then replace the bulbs from the inside.
