1500 can only signal right
Old Oct 17, 2011 | 04:15 PM
team_realtree's Avatar
team_realtree
Default 1500 can only signal right
Is this something common that I can tackle on my own? No matter if I push the signal thingy up or down it signals right. But if I don't lock it down just manually hold it down it will signal left.
I'm not sure if I should be tearing apart that part of the truck to see what is up with the switch because of the airbag.
Old Oct 17, 2011 | 11:03 PM
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
That would most likely be the multifunction switch.
Tear the steering column apart and replace it.
Old Oct 18, 2011 | 08:18 PM
Caseys-dodge's Avatar
Caseys-dodge
Make sure you disconnect the battery and wait at least 2 minutes to completely disarm the airbag system before you start working on it
