2005 1500 Intermittent blower fan
Old Oct 18, 2011 | 05:26 PM
Stradic's Avatar
Stradic
Default 2005 1500 Intermittent blower fan
About 9 months ago, I noticed that my blower fan would not blow out onto the floor when I turn the selector **** to "Heater". The most it would do is mostly blow out the defrost vent and a little on the floor. Then it started not blowing anything at all. I noticed that when I fiddled with the key in the ignition, I could get the fan to blow. Now, after starting the truck, I have to turn the key to the first click towards off to try and get the fan to turn on.
I replaced the starter switch (I think that's what it's called) the black module on the left hand side of the steering column. I got my blower fan to work, except for the half and half blowing out the floor/defrost vent while on "Heater", and I thought I had everything fixed for about 2 days until my windows quit working. I put the old switch back in so I could have my windows again but now it's getting colder out and I need to find a solution. I've searched online and can't seem to find anything like this problem. Does this sound familiar to anybody?
Thanks
Strad
Old Oct 21, 2011 | 09:32 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
if you have to jiggle the keys to get the fan to work then thats a dead giveaway the ignition switch is the culprit
Old Oct 24, 2011 | 01:08 AM
Stradic's Avatar
Stradic
Thank you for your response. I replaced the ignition switch. The fan blows like it's supposed to now but now my windows don't work. Actually, the windows worked for about a day, now they don't work. No "jiggling" of the keys gets them to work either. Do you have any other suggestions?
Thanks
Strad
Old Oct 24, 2011 | 01:11 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
the solder joints in the master window switch are either loose or the contacts in the switch are bad. I think there is a DIY in the link in my sig. Check there and see if that resolves your issue
