6.1 Ignition conversion kit.
Old Oct 21, 2011 | 06:33 PM
hemibee's Avatar
hemibee
Default 6.1 Ignition conversion kit.
HI all
sorry have not been here a lot.
I would like to know how hard it will bee to change out my 5.7 valve covers to the 6.1 valve cover conversion kit ?? i will bee gettin it for x mas i seen some where that there was a thread with pics and how to do it. but i cant find it.
thanks 4 any help
Old Oct 21, 2011 | 08:59 PM
HemiLonestar's Avatar
HemiLonestar
Weedahoe has some pictures, I think he did a write up for it too. The connectors are different for the 6.1 coils.
Old Oct 21, 2011 | 09:04 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
I have this on my truck. Its not hard. Valve covers are a direct swap and need a deep 8mm to take them off and on.
The coil harness plugs on your current engine harness have to be cut off. Notice there are two wires on each harness plug and all harness plugs have one wire color in common. That same color wire on each harness is the ASD (Auto shut down) wire. The other wire is a different color on each harness and is the coil wire.
So basically you cut the current harness plug off, splice on the new harnesses, install the VCs, install the new coils (10mm BTW) and connect the harnesses to each coil
Here are some pics of mine
http://tinyurl.com/3dwh4td
Old Mar 31, 2013 | 08:37 PM
hemibee's Avatar
hemibee
weedahoe, how ya doin. on the 6.1 wire conectors it looks like. orange wire to blue & purple wire to brown. is the right ? and i finaly got the 6.1 conversion kit
thanks joe
Old Mar 31, 2013 | 08:40 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Sorry boss, it's been a while since I've even looked under my hood, much less crawled on top of the engine. Shoot me a PM to remind me to look if I don't get back to this tomorrow during the daylight
Old Apr 1, 2013 | 05:58 PM
hemibee's Avatar
hemibee
HI bud what did you find out about the wires ?
Old Apr 4, 2013 | 11:12 PM
69rrbruce's Avatar
69rrbruce
If you look at the open (coil) side of the connector with the bump-out (tang) on top, the lefthand #1 position is for the Coil Control wire which should be wired to the dark blue w/ a different color tracer for each coil. Then the middle #2 position is for the ASD Control Output wire which should be wired to the brown w/ white tracer wire. The right #3 position is left empty. If I remember correctly my connector kit came without the orange & purple wired pins inserted and I don't remember if they were the same gauge or not. If they are different gauge wire the heavier gauge wire should go in the middle #2 position.
Old Apr 4, 2013 | 11:15 PM
69rrbruce's Avatar
69rrbruce
Had another thought. Do you have a the capacitor for connecting into the ASD Control Output circuit?
Old Apr 9, 2013 | 09:15 PM
hemibee's Avatar
hemibee
so it looks like the ORANGE TO BROWN WIRE #2 hole or center.
and purple to blue wire # 1 hole.
sorry for so many questions but have not done this before. i want to get it right the first time.
thanks joe
Old Apr 10, 2013 | 08:25 AM
SLT8's Avatar
SLT8
looking good weedahoe.
