Engine Noisy and Check Engine Light
Old 10-24-2011, 10:16 AM
DumbCarGuy's Avatar
DumbCarGuy
DumbCarGuy is offline
Default Engine Noisy and Check Engine Light
I've got a 2004 1500 4.7. My Engine is pretty noisy although it seems to run fine. The check engine light is on and I get codes P0456, P0440, and P0430. Any suggestions other than taking it to an expensive mechanic which I can't really afford right now.
Old 10-24-2011, 12:19 PM
dodgeboy1979's Avatar
dodgeboy1979
dodgeboy1979 is offline
Ok, the first two codes you listed should be for your EVAP system, check and replace your gas cap as a starting point, then check all the hose clamps for tightness the last code is for your CAT system efficiency, sounds like either your CAT is plugged or an o2 sensor is gone.
Quick Reply: Engine Noisy and Check Engine Light
