Fix for Dodge Ram Stalling Issue
Old Oct 24, 2011 | 05:04 PM
jimbopa's Avatar
jimbopa
Smile Fix for Dodge Ram Stalling Issue
I had an issue with my 2005 Dodge Ram 1500 Hemi stalling, sometimes it would happen at a light and other times while making a turn. The truck would run fine one minute and then when you were at low idle it would feel like it was going to stall. I had it in the dealership on four occasions and they were never able to find the issue. The codes red P303 or multiple cylynders misfire. I changed all the plugs, the plug wires,fuel pump and pressure checked, egr valve, the throttle body was cleaned, fuel injectors cleaned and for a time it would run fine and then come back. Finally, I met a tech who took it to the next level-he indicated that Dodge advised him to reset the adaptive control module and then drive the truck so it learns the right fuel mixture ratio. I have not had an issue in teh last 10K miles. WHY did it take so long to fix, poor communications I wanted to post this so others having an issue can now take the truck in and get to the root of the problem. Good luck.
Old Oct 24, 2011 | 07:37 PM
lxman1's Avatar
lxman1
Site Moderator
Some mechanics overlook the obvious. I would have cleaned the throttlebody and then pulled the PCM memory fuse for about 30 min to reset it myself.
Oh yeah, welcome to the forum.
