gear question
Old Oct 28, 2011 | 06:20 PM
mikh338636's Avatar
mikh338636
Default gear question
so i am thinking about doing 4.10s or 4.56s. stock i have 3.55s with the lsd. my question is, can i keep my stock lsd and just upgrade the gears? im thinking yes but want to double check before i order my stuff.
Old Oct 28, 2011 | 07:33 PM
HammerZ71's Avatar
HammerZ71
Yes you can, but why? I'm actually amazed with an '02 the LSD hasn't spit it's clips out and grenaded the diff by now...
Old Oct 28, 2011 | 08:43 PM
mikh338636's Avatar
mikh338636
so you think its prly a good idea to replace the lsd as well. i rather not spend all the money on having gears installed to have the lsd fail after...
Old Oct 28, 2011 | 09:43 PM
HammerZ71's Avatar
HammerZ71
Never been a big fan of the Mopar LSD, even without the "c-clip" issue. Most of the time just to get it to engage you either have to apply a little brake with the gas or set the e-brake slightly on with the gas.
If you have the funds, have either an Auburn or TruTrac installed when they do the gears, there is almost no extra work involved if they are in the housing anyway...
Old Oct 28, 2011 | 10:35 PM
mikh338636's Avatar
mikh338636
this sounds like its going to get expensive, maybe i wont do this afterall
Old Oct 29, 2011 | 12:17 PM
SLT8's Avatar
SLT8
I agree that if you have the funds then you should upgrade the lsd the same time as doing your gears. That said i am still running the oem lsd @ 120k and have been through 3.55's,4.10's,4.88's
Old Oct 29, 2011 | 01:00 PM
mikh338636's Avatar
mikh338636
i know many of the sites you guys shop on for dodge parts but what sites have you found to have the lowest prices for gears and possibly an lsd
Old Oct 29, 2011 | 01:05 PM
SLT8's Avatar
SLT8
For new products, airram.com would be a good option.
http://airram.com/product.php?catego...&productid=170
Motive Gears for 9.25 = $199.99
DTT = $520
MIK = $94.99
$814.98 w/ free shipping
Old Oct 29, 2011 | 01:11 PM
mikh338636's Avatar
mikh338636
another 500 or so for an auburn or trutrac ill have to see about that. as far as the gears i would have the chrysler 8" up front and 9.25" rear? also i need the ring and pinion and master install kit for both front and rear and i should be all set?
Old Oct 29, 2011 | 01:19 PM
SLT8's Avatar
SLT8
DTT is the trutrac.
It would be an additional 245.60 to add in the 4.56 8.0" gears and MIK.
So total around 1,132.77 w/ free shipping. You may get lower than that if you look around. Just throwing airram out there as an option.
