Another oil thread
Old Nov 1, 2011 | 09:10 PM
hdwg's Avatar
hdwg
Default Another oil thread
Bought a 08 1500 4.7 last March...dealer gave me my first oil change, came time again and I threw in 5w30..Live in Indiana so, it will be getting cold here soon. From what I have seen does not look like it will be a problem. Anyone have any issues?
Old Nov 2, 2011 | 12:02 AM
Brandon Anderson's Avatar
Brandon Anderson
I would use the recommended 5w20 if it were my truck, but that's just me.
Old Nov 2, 2011 | 06:56 AM
MikeHTally's Avatar
MikeHTally
It calls for 5w-20. Since it gets pretty chilly up there, -30 may not flow well enough.
Old Nov 2, 2011 | 07:48 AM
pitbull24's Avatar
pitbull24
Never had an issue running 5w20 over here in Chicago.
Old Nov 2, 2011 | 01:29 PM
hdwg's Avatar
hdwg
Just grabed the 30, just so used to it, guess I will give it a month and change it again when it really starts getting cold.
Old Nov 2, 2011 | 07:18 PM
dirtydog's Avatar
dirtydog
Moderate User
You've got the numbers backwards. It's 5(Winter)-30 operating temp.
The Winter number is what oil is at when cold started. Oil then changes visosity to the higher number once warm providing better protection at higher temps.
30 weight won't flow as well as a 20 weight so you will definately set off an internally stored DTC code. This does NOT set off your check engine light, but your Dealer will be able too hook up a Scantool and find the code of incorrect oil weight. It's insignificant to them really but the only effect that you would be concerned about is that you have MDS and it may not function all the time because of the different viscosity rating.
I have my MDS turned off and choose to use 5w-30 for the better protection. 30 weight has half again as much viscosity than 20 weight but that also means it takes that much more time to flow...which is why the MDS lifter can fail to activate.
Old Nov 2, 2011 | 08:41 PM
MikeHTally's Avatar
MikeHTally
I don't have the numbers backwards. I know very well what they mean. The engine calls for 5w-20. -30 is thicker than -20 at operating temperature, so it won't flow as well. The outside temperature is irrelevant. 4.7s don't have MDS.
Old Nov 2, 2011 | 08:54 PM
Manvin's Avatar
Manvin
unno if you care that much, But is the weather gets very cold, I would recommed using synthetic oil if you park outside. conventional oil doesnt lubricate well in temprature extremes..
Just a thought.
Old Nov 2, 2011 | 09:09 PM
MikeHTally's Avatar
MikeHTally
Um, viscosity is viscosity, dino or synthetic. Synthetic handles heat better, hence its use in boosted motors.
Old Nov 2, 2011 | 10:38 PM
Atwiss's Avatar
Atwiss
i live in nebraska and this is my first oil change that ive done my dad uses my truck some times and he usually change it but would 10w30 be fine or is that more of a summer oil?
