2003 5.7 Mising Badly / Low Vacuum?
Old Nov 9, 2011 | 05:29 PM
billonthebox's Avatar
billonthebox
Default 2003 5.7 Mising Badly / Low Vacuum?
I have a 2003 Dodge Ram Slt Quad 4x4 w/5.7. Truck was running great then all of a sudden while driving it stalled. Pulled over, now it barely runs??? Vacuum test shows 4" vacuum at idle and 15-20 at 2000 rpm. It only throws a a 300 code???
We have pulled intake manifold off, seams OK. Compression test all within 15 lbs. Pulled valve covers off springs ok? Wires and loom, OK. Fresh factory plugs, OK.
Truck has 80,000 (Bought New) and has always run Perfect?
Help!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Bill
Old Nov 9, 2011 | 06:15 PM
lxman1's Avatar
lxman1
Site Moderator
I would start with checking the fuel pressure. If good, then perhaps the crank position sensor.
Old Nov 9, 2011 | 09:11 PM
billonthebox
How about timing chain jumping a tooth?
Old Nov 12, 2011 | 07:56 PM
Toolman74's Avatar
Toolman74
Wow you guys really ripped it apart. I'm willing to bet my last dollar it's the fuel pump.
Old Nov 14, 2011 | 01:26 PM
billonthebox
Yep, both heads coming off for valve jobs and springs, probably new rods, timing chain and water pump as well. With the new paint job...hope it goes another 50 - 70k???
