Rattle going over small bumps
I had a mysterious rattle that was identical on two Rams. Finally had enough on the second, and found it to be the input shaft on my steering box. Just a little bit of lateral play , caused a subtle rattle at any speed, and the smallest bumps. If your ram has a steering box, grab the steering shaft just above the box and give it a wiggle. Any play at all will give you a rattle going down the road.
Btw, my solution was a large zip tie around the shaft, and through the shock tower. Just enough tension to keep the shaft from bouncing around. It feels like a new truck again.
2006 Mega 1500 4x4
2006 Mega 1500 4x4
on
2006 Mega 1500 4x4
2006 Mega 1500 4x4
2006 Mega 1500 4x4
I have an '08 with passenger side clunking over small bumps as well. Try this link:
https://dodgeforum.com/forum/3rd-gen...xed-today.html
Next trip to the dealer I'll have this printed for them
I'm sure the OP was talking about a much deeper and heavier metallic rattle than you'd get from a piece of gravel. It's like something big and heavy is loose. Imagine, say, someone forgot to put the bushings in some component down there.
Rattle sounds like glass bottles rattling
My 06 Magnum R/T has a rattle, but stops with braking. Only over bumps. The brake pads will rattle in the caliper but are quiet with any amount of braking. I resolved mine with a new hardware kit. Essentially those little metal clips that go between the brake pads and the caliper. Remove the 2 small bolts that hold the caliper on, (dont let the caliper hang on the brake line) slide out the pads, clean everything up real nice then re-install the pads and caliper after CAREFULLY putting brake grease on the contact points. Dont get anything on the pad surfaces or disks!
