Antifreeze leak somewhere.
I have a 2002 Ram 1500 with the 5.9 engine. I can smell antifreeze . I can't find the leak. It takes about 3 months before I have to add to the overflow bottle and I don't see any drips on my driveway.When I was changing my oil filter there was a couple drips of antifreeze on the outside of it. Any idea where this could be comming from? The heater hoses appear to be ok.
I had the same issue last year i was smelling antifreeze but not seeing any leak and no drop in coolant level , and after a long search i found a tiny drops on the radiator from inside it gave me headache to find it , but in ur case as Hammer said check the gasket around the Tstat, good luck
check the tanks on the radiator too, I had a similar problem with an old 5.2 Dak I had, just a tiny weeper that drove me crazy until I pressurized the cooling system and watched it start leaking out
