Fasten Seatbelt Noise Removal
Old Nov 29, 2011 | 12:35 AM
TRX-HD's Avatar
TRX-HD
Default Fasten Seatbelt Noise Removal
Anyone know if there's a code or fuse to remove in order to get rid of the "fasten seatbelt" tone?
Old Nov 29, 2011 | 01:16 AM
lyndo's Avatar
lyndo
i believe the procedure is:
starting with the seatbelt buckled: turn the key from off to on (don't start the engine), wait for the seatbelt light to go off,
Next, buckle and unbuckle the seatbelt 3 times (i believe?) finishing with the seat belt buckled. Now turn the key off and you should hear a chime indicating that it was correctly programmed.
edit: apparently I had the thread bookmarked where I got this from, props to yodahog from ramforumz:clicky
Old Nov 29, 2011 | 09:09 AM
TRX-HD's Avatar
TRX-HD
Really? That works?
Old Nov 29, 2011 | 09:11 AM
TRX-HD's Avatar
TRX-HD
Will this work on a 07 2500hd?
Old Nov 29, 2011 | 09:38 AM
Marklorenzo's Avatar
Marklorenzo
Beeep......beeeeep.......beeeepppp.....beeeep..... ......................................just when you think its done.....BEEEP.
Old Nov 29, 2011 | 10:01 AM
lyndo's Avatar
lyndo
its worth a try, it worked on my 07 1500
Old Dec 1, 2011 | 12:51 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
This was long before I knew there was a key trick but I took one of these and bridged the two wires together on the seat belt harness and it was a done deal
Old Dec 5, 2011 | 12:32 PM
TRX-HD's Avatar
TRX-HD
Oh nice.
Old Dec 5, 2011 | 12:33 PM
TRX-HD's Avatar
TRX-HD
Oh yea I forgot to ask, whenever I have to delete code faults with an OBII scanner, will it allow me to keep that code or will it reset it everytime?
