4.7 idle off after fastman tb installed
Old Dec 6, 2011 | 09:17 PM
boxerguy84's Avatar
boxerguy84
Default 4.7 idle off after fastman tb installed
My idle is acting up after I installed a 68.5mm Fastman throttle body. It doesn't do it all the time but maybe 50% of the time when I slow down to a stop the idle seems to rev up and down. I unplugged the battery the whole time I was installing it to reset the memory or whatever. I haven't done anything else that would cause this besides the upgraded throttle body. Anyone have a solution? Is it just in "learning mode" still?
I've got a video I made of it you can see by clicking the youtube link below.
http://www.youtube.com/embed/UzDRMP5Vrc8
I just remembered that one of the O-rings on the IAC was a little stretched out and should be replaced. I'm going to replace both O-rings tomorrow and see if it fixes that idle issue.
Last edited by boxerguy84; Dec 6, 2011 at 09:48 PM. Reason: Remember the IAC o-rings
Old Dec 7, 2011 | 04:59 AM
bwdakrt's Avatar
bwdakrt
Sounds like it may just be relearning the new air flow.
With the engine cold, disconnect the negative battery cable for 1-2 minutes, reconnect and start engine (DO NOT REV) letting it idle and come up to operating temp. Shut engine off, restart and go for a drive making as many stop & go's as possible, such as stop signs, to help the PCM relearn the part throttle settings. See if that helps.
Old Dec 8, 2011 | 12:47 AM
boxerguy84's Avatar
boxerguy84
I replaced the IAC valve and TPS sensor and my truck is running awesome!
