35 inch tires on stock 17inch rims with no lift kit
3rd Gen Ram Tech2002-2008 Rams: This section is for TECHNICAL discussions only, that involve the 2002 through 2008 Rams Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
You also have to consider that there is a BIG difference between having a tire that fits and having a tire that fits and leaves the truck useable.
Seen a bunch of trucks around here riding on big meats that scrub at every turn, can't hold more than a couple hundred pounds in the bed or has enough articulation to get over a speed bump much less be able to do anything off-road...
I have 35s on 2 inches in the front with partially trimmed fenders and at full turn I don't scrub.. If im on a hill and turn it all the way that's the only way they do...
