Help with 4x4 not engaging
I was on my way to work this morn (in 4x4 auto) when I hit a small pothole in the road. Immediately my headlights, dashlights, heater etc. all started powering off and on at about 2 second intervals. After about 6 or 7 times doing this they came on and stayed on. I turned around and came home. As I got home, I could not back up my (snowy) driveway. This is when I realized that 4x4 was not engaging. I tried all other settings, as well as starting and stopping engine, disconnecting battery, cleaning terminals, checking for loose wiring but nothing. Dash shows 4x4 auto but truck will not come out of 2wd. Flashing lights have come back as well. Complete power failure for 2 secs then back on then off, on, and so on. Engine has shown no symptoms. Continues to purr. Any help would be appreciated. specs below
2008 dodge ram 1500
quad cab
5.7l hemi
Scott
2008 dodge ram 1500
quad cab
5.7l hemi
Scott
It is a **** that you turn that has 4 different selections...2wd/ auto/ lock/ and low. I will try the connector in the morning. Thanks for the advice
