bad egr vavle?
Old Dec 19, 2011 | 07:38 AM
jgregory01's Avatar
jgregory01
Default bad egr vavle?
I have a 2005 Duranga limited w/ 5.7 hemi 4x4, 77k miles. I know, its not a ram but someone suggested asking herfe aswell due to similar enngine as the Ram.
I have noticed lately that when stopped my engine is idling a little rough and the tach will bounce just a little. Not much movement, no sweeping of the needle, just small bumps over 700rpm.
I have had the egr clean ed twice because of cel codes. Could this be the egr again and should I just replace it? Also, if that is the cause should I also change pcv? Thanks
Old Dec 19, 2011 | 11:37 AM
MikeHTally's Avatar
MikeHTally
How many miles on the plugs? Has the PCV valve been cleaned/replaced?
Old Dec 19, 2011 | 11:48 AM
HammerZ71's Avatar
HammerZ71
I've never gotten more than a month or two out of cleaning a bad EGR, replace it for the $30 it costs at an auto parts store...
Old Dec 19, 2011 | 12:28 PM
jgregory01's Avatar
jgregory01
Plugs replaced 10k ago. Never changed PCv. I don't know if I'm making more of this than I should. The idle is not very noticeable and the rpm jumping is not noticeable unless you stare at it
