How to remove lower strut bolt?
Old Dec 28, 2011 | 03:09 PM
IowaHemi1's Avatar
IowaHemi1
Post How to remove lower strut bolt?
I cannot get the lower strut bolt off, from the lower control arm on a 06 ram 4x4. Broke a impact socket trying. I used wd40 and also beat on it with a big hammer. Any tips on how to remove this bolt? My strut is leaking and i need to replace it.
Old Dec 28, 2011 | 11:01 PM
barksatbirds's Avatar
barksatbirds
https://dodgeforum.com/forum/3rd-gen...dbeardmcg.html
Try this, it's off topic but part of his project is removing the strut.
A LOT of us have had trouble removing this bolt, you may want to buy replacements at the dealer and sawzall the bolts out.
Hope that helps.
Old Dec 29, 2011 | 01:45 AM
dakotatrevor's Avatar
dakotatrevor
Air hammer, heat, or a press. It took all 3 to get one of mine off. Remember, you cannot replace that particular bushing, short of replacing the whole control arm, so be nice to it.
Old Dec 29, 2011 | 05:20 AM
Xler8er's Avatar
Xler8er
I used a ball joint press and used a hammer on the end you tighten down after each time you torque up the press.
